I WANT A 13 TOOTH FOR PRED
bradr6 - I ordered a sprocket for an xr650r. the xr650r sprocket is thicker than the predator sprocket. my mistake in not paying attention to the L and R in the 650. lucky for me i work in a machine shop so i machined the extra width off and it works prefect. i should have checked to see if it would have fit before i modified it.
after i put the 13 on my quad i decided it was still a little bit to high geared so i have a 39 tooth rear on the way from sprocket specialist.
13 39 that would be the same gear set up that the old TRX250R uses.
It should really bring the low end power a good boost.
turbo bobby
turbo bobby
I've been once before. I went the year before last and ran my sport with a trail mod and port. It ran a 6.1 at 48mph. I now have a sport with hpd race mod and it's lightened a bunch. I hope to run in pro 2 as well. I would imagine you'll be at the test and tune on Feb 22. I should be there as well.
BYC
09-25-2015 02:10 PM
Hankey Pankey
07-31-2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
07-29-2015 10:57 PM
