will a sportsman 500 H.O. run with the air box cover removed.
I got a sportsman 500 H.O. 2001 the Question that I have will it run with the stock carb and with out rejetting, if I take the air box cover off.
I don't plan on doing this I just want to settle a 20.00 bet that I have with my brother.
He says it will run, I say it will not it will sputter and sound like crap.
I would try it on mine but it is at the cabin.
please help.
Thanks Shedhead
please help.
Thanks Shedhead
It most likely will run bad, will run lean because of increased air flow. Will cut out when you hit the throttle. Tryed this with my trail boss and it ran like crap. If you run it lean for any length of time you could burn a hole in the piston.
So if you open up the air box for more air flow is it possible to rejet back to the correct mixture through the full throttle range? I realize this means the needle will need lifting and a larger main. Will this improve performance significantly?
