does anyone know how to by pass reverse overide on sp700
i find this a pain in the @@@ when plowing snow or pulling my buddys out of holes.[img]i/expressions/face-icon-small-smile.gif[/img] i would appreciate any info, thanks
I have seen some stuff on ebay pertaining to what you are asking about. What I have seen on ebay is a kit to make all 3 of your front lights work at once and included in the kit was the reverse override kit. I think it was like 15 bucks or something if I rember right, it looked like you have to install a different wiring harness maybe?? Just go to ebay and type in polaris sportsman in the search box, if you start your search from ebay's home page make sure you search again when some matches come up and check the little box marked title and description in the search box, it helps bring up more matches...
here is a item number for an auction at ebay for a reverse override. the item number is 2404855942, just type the item number in the search box and it should take you to the auction..
IN YOUR HEADLIGHT POD LOCATE THE GREY/ORANGE AND THE PURPLE WIRES, RUN A JUMPER BETWEEN THEM. YOU CAN CHECK TO SEE IF IT WORKS BY SHIFTING INTO REVERSE AND SEE IF SLOW FLASHES ON THE SPEDO.
you could probably run a wire from the wires going to the top headlights to the wires going to the bottom lights so when you turn one of them on both will get power. Probably not the best way but it should work. Or try running both wires to the switch and hook both of them up to either the high or low beam side.
