Sticky Situation Scrambler 4wd
If you don't use the type F you risk compatability problems with the fluid already there. If you can't find it, you might be best off to use the Polaris hub fluid. Takes only a couple tablespoons worth, so even though it is kind of overpriced, it won't break you.
I have to take apart my hubs anyway to replace the seals. I cant find anyone around here that has the type F, just the regualr synthetic. And my nearest dealer is 40 miles away. So, if I take apart the hubs and clean everything with brake cleaner, then I shouldn't have any problem running the normal Mobil 1 Synthetic ATF???? Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
