whats the purpose of reeds?
Hey Hazard, here are some really good links on jetting. An easy way to tell if you are to rich or lean is to flip on the choke at the suspected throttle range. If it gets better then it is lean, if it runs worse it is rich. Of course the best method is to check your plugs. Read these links very carefully, print them, keep them, it is good info and will be of benefit to you. Tuning Carbs. Hope this helps you understand tuning.
