gear selector light is stuck in reverse
Old May 9, 2003 | 05:05 PM
bad2's Avatar
Default gear selector light is stuck in reverse
I have a polaris Scrambler 2002 500 4x4
I tried to wire up a cigarette lighter by using the red accesory plug under the hood, as per the wireing diagram.thats when the trouble started. cigarette lighter works fine so I dont know If it was the caulse or a coincidence. But now the gear selector light is stuck in reverse no matter what gear i am in. therfore I have to hold the override button in even when going foreward. I disconnected the shift selector switch at the transmission and now it will go foreward without having to push the overide button but no lights come on to tell me what gear the machine is in. anyone have any ideas what is wrong??? or how to test the individual components to find out what is bad??
Old May 9, 2003 | 09:04 PM
kblazk's Avatar
put it back the way you had it before and see if it still does it, you could also have pinched/crossed a wire in the process of installing your lighter
Old May 9, 2003 | 10:04 PM
bad2's Avatar
I have disconnected everything and still the reverse light stays on. if i disconnect the gear selector switch at the transmission the light will go off and i can than drive in foreward without using the override button but no lights come on to tell me what gear it is in. there are no pinched wires. I think i must have destroyed the gear selector switch does anyone know how to test it???
Old May 10, 2003 | 01:27 AM
scmudboy's Avatar
i can tell you your switch is bad. I have a bad one and have not priced a new one yet. Dont think they are much. Two screws and pulls staight out.
Old May 12, 2003 | 06:49 PM
bad2's Avatar
Thanks all for your input I replaced the gear selector switch on the weekend.
and everything is working fine now. a $48.00 can learning lesson.
great forum and again thanks for the help
KimSJoh
14
Jul 18, 2015 07:20 PM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
