WB vs HMF comparision
Old May 15, 2003 | 02:43 PM
  #41
SP700RACER's Avatar
Default WB vs HMF comparision
Why should I share it. you and the Superbike basher's just use false information to try and discredit the results. You can't imagine the testing that has been done. But a little info on pipes, the MBRP tested with the best results on a stock bike.(stock air box). But with some additional work on the carb slide, it will probly make even better numbers. You can verify this by contacting 14MINS.
Old May 15, 2003 | 04:56 PM
  #42
01ds650's Avatar
I understand the MBRP headpipe to line up on a DS like a stock headpipe. The result is a HMF slip-on will fit on a MBRP headpipe. However will the headpipe improve anything? Does anyone know that?
I was told it was hard to improve upon the stock DS headpipe unless you go heavily modded anyway.
RedRancher
Aug 31, 2014 09:08 AM
Stumppuller1
Nov 18, 2009 12:57 PM
mark63
Nov 12, 2006 11:22 PM
sxr6
Apr 20, 2001 08:20 AM
robg
Mar 21, 2001 09:05 PM
