07 sportsman 500 speedo
Hi opt,
a month ago o bought a brand new speedo and have not had any problems. I went out to start the wheeler the other day and nothing lit up on the speedo... I pulled it out to check it and it seems everything is still plugged in. Is there s fuse that feeds that? Or a wire in that cluster that should have power that I can test? My brother has a 2010 and if his is the same speedo I will plug his in to see if it works.
thanks
thanks
