Wiring Help Please!!!!!
If your bike came with electric start and a battery, it will already have a charging circuit and rectifier. If it is pull start only with no lights, it will not have a charging coil on the stator, but if it is pull start with lights, they are worked directly by AC so, in theory, a rectifier/regulator placed in the lighting circuit could be used to charge a battery.
The three yellows seem to indicate a three phase alternator for charging, if so, you need a 5 pin regulator, these are pinned out oddly, so be sure you know how to wire it up. I guess you could use two phases and the four pin reg, but it won't work as well, and Chinese 5 pin regulators are almost being given away at the moment.
Yes mine had electric start and a battery. I ordered a wiring harness from Amazon because the previous owner had rigged the wiring. It was melted in spots and some of the wires were just cut. The harness I ordered came with the wrong stator and I'm not sure if it came with the right CDI. I was trying to make it work. The original CDI is a bit bigger than the new one, which leads me to believe the old one is DC. It's still in good shape, so I will try it. And I managed to find a 5 pin reg. It has 3 yellow wires, a green, and a red. Is the green ground and red +B? If my reg isn't good, where could I buy a new one? I can't find any info on the engine I have. Thanks for the reply!
Okay so I re checked my engine, and I made a mistake. I have 3 yellow, 1 blue/yellow, 1 green/white from the stator. I'm not sure what CDI I have. It is larger than the new one I purchased. I believe it is a DC CDI. But it has a blue/white, yellow/black, solid green, and green/white going to the 4 pin. And a solid black and a blue/white to the 2 pin. I am lost. I read that DC CDI has only one wire on the 2 pin. I just need a simple wiring diagram to run, turn off, and charge.
Did the Amazon harness/stator/CDI set up not come with a wiring diagram? Do not try to run a DC CDI on the new set up unless you are very experienced at auto electronics, it needs to be matched to a coil for DC, for one thing. There are so many different ways of wiring a bike up, and the Chinese seem to use every different one of them, so I am wary of those "one size fits all" kits. Are you saying the new stator will not fit onto your engine, if so, you may not be able to make the rest of the kit work.
I'm using the original stator, but I purchased a wiring kit. The CDI that came with the kit is smaller than the old one. The old one had 4 wires on the 4 pin and 2 on the 2 pin. The 4 was blue/white, Black/yellow, green/white, and green. The ones on the 2 pin was blue/white and solid black. But I only have 3 yellow wires, a blue/white, and a green/white coming from the stator. I'm not sure if there is supposed to be a red/black or what.
Your best bet is to buy one off of the Coolster website itself. Too many different wiring harnesses.
harleysparkplug
Tread Depot
11-07-2012 12:01 PM
