CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Ds650 baja not starting
Old 06-24-2018, 05:25 PM
Stump1013's Avatar
Default Ds650 baja not starting
Ok guys needs some help asap ready to set this thing on fire..thing would never start valves were tight i adjusted the calves to correct shims on intake n exhaust have plenty of clearance in between cam lobes n shims..problem is i done set tdc about 10 times now its dead on..will not fire one hiccup sprayed gas into carb while cranking n while not all it does is make a loud backfire n some flames come out. Its like valves are tight but there not.idk how it could be firing wrong with it at tdc. I need help asap carn is clean have plenty of spark bright blue.
Old 06-24-2018, 07:02 PM
hondarancher3502005's Avatar
Have you checked to see if the timing is off?
Old 06-24-2018, 07:06 PM
Stump1013's Avatar
Timing is dead on.thats wjy im confused not sure what is going on
Old 06-24-2018, 07:08 PM
Stump1013's Avatar
I have cams top dead center rechecked 5 times re set about 8 times. You mean timing as far as flywheel?
Have you checked to see if the spark is hot enough and what color is it? Should be a bluish color.
Old 06-24-2018, 07:10 PM
Stump1013's Avatar
Yes have bright blue spark on each coils. Plugs are dry even when i spray gas through intake.
Old 06-24-2018, 07:20 PM
And its backfiring out of the carb? just like a loud pop?
Old 06-24-2018, 07:33 PM
Stump1013's Avatar
Yes only when i spray gas through intake. With carbed hooked up i dont get no pop or anything.
Old 06-24-2018, 07:47 PM
Have you checked the cleanliness of the carb?
Old 06-24-2018, 07:57 PM
Stump1013's Avatar
Yes i cleaned all jets and i have proper gas flow from tank to carb but its either not entering engine or timimg is off somewhere.plugs are dry n still brand new not a hint of gas on them.
Quick Reply: Ds650 baja not starting
