86 Suzuki 230s
86 Suzuki 230s
Ok I just bought a 86 Suzuki lt230s I believe i really don稚 know what it is all I know is it semi auto which I知 saying that because you have to shift but with no clutch. Now I知 having piston ring issues I tore the head off of the motor and got to the piston then I noticed it has 0.50mm stamped on top of it and underneath it says 4382p2 now I知 not to sure what it means so I basically have looked up the piston and rings the quad as from the factory and it says 66.0 mm piston and rings. So I guess I知 asking what the stamping on the piston means and what piston should I be looking for to get. Please if someone could help id appreciate it.
Probably means it has been bored out to 66.5mm. If you can't check it yourself, get someone to check it for you. If the rings are badly worn, what is the bore like? Always best to check piston diameter, ring gaps, and bore diameter when you have the engine down. You may only need new rings, if the piston is OK.
defconatv
04-27-2008 01:26 AM
