Burning wire while starting
Old 09-18-2018, 10:13 PM
Ken13's Avatar
Default Burning wire while starting
Hello all,
I have a 2002 Eton Yukon YXL 150. I can shift from F,N,R and the correct light turns on. The brake light works. When I went to start the quad the light jumped form neutral to forward and a wire heated up and melted the insulation. The wire runs from a 4 pin connector on the left to in front of the shift lever on the right. I would like to fix the quad so I may donate it to a Horse rescue place where I volunteer. Any ideas would be apprciated.
Thank you,
Ken
Old 09-19-2018, 02:04 AM
Sounds like a bad main earth cable to engine from battery or frame. If so, the neutral wire could then be turned into the main earth for the starter, overloading it.
Ken13
09-18-2018 06:15 AM
Snowcatxx87
06-14-2018 09:52 PM
Mark0524
03-02-2015 02:59 AM
mykool61679
04-29-2007 01:04 AM
Raptorboy4life
03-02-2004 02:13 PM
Quick Reply: Burning wire while starting
