2000 forman es 450
Old 04-12-2019, 09:52 AM
218christ01238's Avatar
Default 2000 forman es 450
Have anybody had shifting problems with this type of atv? It shifts ok when it's cold but drive it for an hour it becomes impossible to shift.
Old 04-13-2019, 01:37 AM
The 2000 model 450 didn't have the "fault code" system of later 450s so you are working blind if a fault occurs. My guess would be either the angle sensor or the shift motor. Although you can theoretically test the sensor, we go for substitution, fit a new one and if the fault is still on, it wasn't the sensor. However it costs nothing but time to strip and check the shift motor for worn brushes or an oiled up comutator etc. Be warned though, the motor is an absolute swine to get back together.
Old 04-13-2019, 06:02 AM
Thanks, I'll look in to it.
Old 04-17-2019, 02:05 PM
exmotocrosser's Avatar
have you tried shifting with the foot shift when you are having problems with the electric shiftÉ, just to help rule out possible causes...
Old 04-17-2019, 02:13 PM
The mechanical shifter works fine.
travlemon
04-15-2019 09:59 PM
rnault3
04-03-2019 03:11 PM
Heathz
03-18-2019 01:32 AM
Anthony1985
02-25-2019 07:13 PM
Kieran725
02-18-2019 02:00 PM
Quick Reply: 2000 forman es 450
