Spark Test Not Right
Hi have a Linhai 300cc quad 4x4 (2011) Not running at the moment , Cranking over and not spark , I've removed spark plug and tested it against engine block getting two sparks when you turn on ignition only , And no spark when cranking engine over I've tested the coil and lead, Cdi and kill switch, stator, all seem good, anyone with any ideas ?
Just been answering a query about Linhai ignition, different model but that spark when you switch on would indicate a Kawasaki 300 style "ignitor" ignition rather than CDI, same as the other Linhai
https://cimg3.ibsrv.net/gimg/atvconn...bbd715207d.jpg
If your wiring is like this, note pos wire from ignition switch to coil and ignitor, then your ignition is the same as most 1980s cars, 12v coil and signal from trigger coil fed through "black box" to give a negative pulse at the right time, to the coil.
Thanks for your reply much appreciated, Looking at the wiring and the Cdi here, the white wire ( ignition) running to coil And a black/yellow (pulse) to coil , when key is turned to accessories, I'm finding the black/yell pulse is also active on the cdi plug, (not just the white ignition wire) ?
As I don't know the model I can't say what an "accessories" position on the switch is for. With ignition on, you will get pos feeding through the coil into the black/yellow if you test it at the ignitor plug. If you are getting a small AC voltage on trigger coil wires when engine is spun over, earth on the earth wire, pos on the (presumably) white wire at ignitor, but no spark from plug, then it is presumably the ignitor at fault (was with the other posters bike) but note the wiring diagram also shows the blue/yellow trigger wire going to a "speed limiter" box, so a fault in that could affect the AC trigger signal to the ignitor. If your bike has the same set up I would try disconnecting the blue/yellow at the speed limiter box and see if the spark has returned.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
