Main Fuse Blowing when Starter Button Engaged
Old Yesterday | 11:26 AM
JBaird's Avatar
Default Main Fuse Blowing when Starter Button Engaged
Main 20amp fuse flows when I hit starter button. With Ignition switch on everything seems normal - dashboard lights/lights work etc.
Attached wiring diagram. Seems to be a fuse between starter button and common to CDI - it is ok. Does that mean issue is with the hot side thru the Starter/Aux starter relay.
Could it be either a bad Starter relay or the Aux starter relay? Or the wiring? The CDI seems ok - but it doesn't get the juice as the fuse blows.
Any help would be appreciated!
File Type: docx
Old Today | 03:13 AM
That is one weird wiring set up. Normally a thick red goes direct from battery to main solenoid, not going through fuse or ignition switch as shown on the diagram. I would check the starter motor is OK and, if it is, feed the wire, top one on the drawing, direct from main solenoid to battery pos post, by-passing the ign, switch and main fuse. Then see what happens when you press the starter button.
warriorking97
06-04-2009 05:53 PM
400L2X4
03-18-2005 10:47 PM
kanz24
10-12-2003 07:00 PM
BUDXXX
08-28-2003 01:52 PM
lively
06-12-2003 12:06 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: Main Fuse Blowing when Starter Button Engaged
