which sport quad has the best suspension?
I agree with YFZRacer, the YFZ currently has the best 'stock' suspension. The Predator is awesome when you add the Fox Rezzies to the front, really helps out a lot. I consider the rezzies 'stock' because they are make for the shocks that come on the Predator. The YFZ you can dial in preload, compression and also rebound. With the Predator you have preload and compression. One thing that I like the Predator over the YFZ is the fact of zero bump steer. If you look at a YFZ, the front tires look like this: / \ while sitting in it's extended form. From what I was told, after setting up the front suspension on it to the rider weight, with a rider on it, they sit more straight.
Cannondale moto and blaze
GasGas 450 and 300
YFZ450
All the above have fully adjustable front and rear shocks
Cannondale speed and Cannibal
Polaris Predator
Have rebuilable or can be upgraded fronts.
After that I would say the DS650. (it weight however makes it a poor jumper compared to the others).
I'd say out of all the listed quads the best suspension ones would be the cannondale and GasGas ones.
Close second would be a tie with the YFZ450 and the Predator.
GasGas 450 and 300
YFZ450
Polaris Predator
Jul 21, 2015 03:03 PM
John Boy
Jul 13, 2015 11:16 AM
