Sport Quads Discussions on sport quads.
IMS Gas Tank Leak
Old Mar 4, 2006 | 10:48 PM
whaleedited's Avatar
Default IMS Gas Tank Leak
Ive got an IMS Gas tank that leaks around the fuel petcock. The mounting surface of the tank is not flat between the nuts in the tank, my question is does anyone have any tricks to flatten the tank so it wont leak? It looks like it was ground with a grinder but not far enough to be flat. Can I hit it with a grinder ? Im afraid it may heat the threaded inserts up in the tank and they will fall out. Thanks for any help.
Old Mar 4, 2006 | 11:07 PM
recon99's Avatar
First i'd try using some kind of epoxy or liquid gasket to seal it up, before you go grinding away at it.
Old Mar 4, 2006 | 11:33 PM
ThrashAndCrash's Avatar
Get a block of wood and wrap sandpaper around it, and touch up the spot that needs it.
Old Mar 5, 2006 | 09:54 PM
I tried the sand paper first and it worked great,the inserts must be brass . They were soft and sanded easily. No leaks now. Thanks for the help
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
bvolks
Sep 13, 2015 12:57 PM
mbriggs
Sep 13, 2015 10:47 AM
