I NEED TO REJET
Old Jun 1, 2003 | 08:29 PM
quadracer239's Avatar
Default I NEED TO REJET
I HAVE A 1986 LT250R BORED 80 OVER,BOYSEN REEDS,FMF PIPE AN SILENCER HOW SHOULD I JET THE CARB?
THANKS
Old Jun 2, 2003 | 08:26 AM
SliderRacer's Avatar
I have an 86 racer too, with the same mods except I'm bored .060 over, and have FMF Torque Reeds. I jetted my carb with a 230 main jet, and it runs like a raped ape. I would probably recommend a 230, 240, or a 250 main jet. I also advanced the timing too. I turned my stator plate approximately 1/8 inch clockwise past the normal timing mark. If you remove your stator cover on the left side of the engine by the gear shifter, then remove the stator flywheel, you'll see the stator plate with 3 coils. On the stator plate there are 3 screws. Also on the plate, by the top most screw, there is a timing arrow that should be lined up with another arrow on the engine casing. Turn this plate clockwise about 1/16 to 1/8 inch. Tighten down the screws and install everything back. Make sure you put the stator flywheel back on with the woodruff key lined up properly. Then install the cover, and you're done. Hope this helps. Let me know if you have any questions.
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
cSchwartz
Jul 9, 2015 02:43 PM
Bm400ex
Jun 22, 2015 09:16 AM
quad_300ex
Jan 23, 2000 10:17 PM
