LT500 PORTING
Old Jul 3, 2003 | 11:53 PM
Jason454's Avatar
Default LT500 PORTING
I am currently running a 88+ top end ported by Chuck E. I dont know the specs. I bought a pipe from ct racing for this application. I dont think I could build one. sprockets: I flipped the counter shaft sprocket around. For the rear I used a old sprocket, cut the outside off and welded the center to a new sprocket. For spacing and centering. Probly not the best way but theres no good machine shops by me. I used the stock 250 radiator with two inline aluminum finned hose coolers. One on top one at the bottom.
Old Jul 4, 2003 | 03:09 PM
Duneaddict's Avatar
Interesting! I've got a game plan to machine the hub and run the rear sprocket on the opposite side... but I'm not sure how that's really gunna work out until I can get the motor bolted up.
I've seen the CT pipes... I'm probably gunna roll my own. I just finished a drag pipe on my 500, and am VERY happy with the results! Big improvement over my old FMF.
So overall, are you happy with the machine? Significantly faster than a 500 chassis?
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
