Help with lt230s
Old Jul 1, 2003 | 01:55 PM
86350x's Avatar
Default Help with lt230s
Does anyone know if a lt 250 motor will bolt up into a lt 230s frame????
Old Jul 1, 2003 | 02:20 PM
lt230racer's Avatar
i dont know, the bottom should bolt up fine, but the 250 may have a longer cylinder and may not bolt up to the top. But someone told me it will bolt up.do you have the 250 motor?
Old Jul 1, 2003 | 03:12 PM
86350x's Avatar
No not yet?? but am looking..
Old Jul 1, 2003 | 06:01 PM
LT250RSuperstar's Avatar
It will fit but I don't think it will bolt right in, it might but not sure. The 250 just has a bigger bore. Anyways halfway through 1987 the 230s lowerend (after the serial# 117324) was changed. So the 1989 and 90 LT250S Quadsports had the same lowerend as the 230s with the engine serial#117325 on up.
Hope this info helps ya bud.
later
Superstar
Old Jul 10, 2003 | 09:10 PM
QuadSportFreak's Avatar
The 250 Motor (providing your LT 230 (229cc) is 85-86-87, and the 250 is an 89) should bolt right in. I believe that even the 96 king quad top end is the same, other than the cam ,and the compression, i believe everything is the same. That would get you up to 280cc (300 jug) instead of 246cc (250 jug). Also, if you could find it cheap, you wouldn't have to shell out big bucks for the 265cc big bore kit.
Old Aug 19, 2003 | 09:45 PM
lt230s4life's Avatar
It will to the bottom but not to the top
Old Aug 20, 2003 | 02:56 AM
rockrider's Avatar
The Quadsport 250 was only produced for two years but it was pretty similar to the 230 since it was the same frame and engine. The 250cc's came from boring out the 230, the stroke should be identical as should everything else in the motor. If you can get the cylinder for cheap then it's just a matter of a new piston, rings, wrist pin and bearing and your ready to go.
Old Aug 20, 2003 | 09:44 PM
MBrooks420's Avatar
The frames were the same in 1985 and 86. I am almost 100% positive the front motor mounts were changed in 1987. The 250 motor would not be a direct bolt in. The front motor mounts on the 85-86 had a plate that bolted to the frame, and then the motor had a bolt that went through it. On the 87 and up, the plate was welded into the frame and just used a through mounting bolt. I looked into putting a 91 motor in an 86 frame and I think it would be fairly easy to make the brackets needed.
lonerider856
Oct 13, 2023 03:45 PM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
230Srider
Jul 17, 2003 06:30 PM
QuadDude05
Jan 3, 2001 01:35 AM
