Z-400 Plug
Old Jul 19, 2003 | 11:46 AM
Biggie24's Avatar
Default Z-400 Plug
OK what's the trick on quickly removing the plug on the Z. I have to take the tank off to replace the plug. This seems like alot of B.S for a spark plug. If anyone can help ie: special tool or something please let me know and thanks. If i'm just doing something wrong you can call me a dumba$$ lol. Thanks for the help!
Old Jul 19, 2003 | 12:14 PM
bulldogz400's Avatar
Default Z-400 Plug
Dumba$$! J/k hehe. Take the tool out of your tool kit that will fit down the spark plug hole. It will fit around the plug, then use a 17mm open end wrench (also provided in your tool kit) and loosen the plug by turning the spark plug tool. Once you have it loose enough you can use your fingers to turn the tool (otherwise takes a LONG time!). Same thing just oppsite to put it back in. Good luck!
Old Jul 19, 2003 | 12:20 PM
Biggie24's Avatar
Default Z-400 Plug
Thanks, I knew there had to be a way. Believe it or not I never used the tool kit. I just looked at it like some chintsy junk.. Well I payed my stupid tax to make myself look like an a$$ on here.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
frostphase
Aug 19, 2015 07:11 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
