stock carb with bore? How high??
That depends on if you offset bore the hole. Removing more materal from the top side.. If too much is removed the trottle slide will not be able to seal correctly at idle, causing a unjustable high idle...... I would remove no more then .04 of a inch.. or 1 millimeter.....
I would remove .03 from top and .01 from bottom side.....
