quadsport 230 info
Old Jul 23, 2003 | 10:52 AM
warrior86's Avatar
Default quadsport 230 info
my friend just picked up a quadsport 230 for 650 and its in decent shape. i was just wondering if anyone has any sort of tips or info about them. just let me know whatever you guys know so i can help him out. Tthe only thing i think it needs is a rear brake job. everything else is fine. thanks for any replies, warrior86
Old Jul 23, 2003 | 05:45 PM
warrior86's Avatar
cmon, nobody has any tips or suggestions? anything would be helpful and appreciated!
Old Jul 23, 2003 | 05:50 PM
owde's Avatar
you def have to get the dg rcm exhaust. it makes a huge difference and a filter will help to
Old Jul 23, 2003 | 06:49 PM
warrior86's Avatar
its my friends actually. for now, its all he can afford although he deserves a lot better. He the only kid around here except for me that actually takes care of his stuff and isnt a spoiled brat. but w/e.
the only thing wrong with it as of now is the brakes. im going to look at it tomorow to see exactly whats wrong. the front brakes work fine but the rear ones supposadly dont work. the guy said it needs a 'brake job". ill tell him about those things and see what he says. thanks, any more replies?
Old Jul 23, 2003 | 08:04 PM
littleR's Avatar
The only thing l did to my 230 to make it faster, was put in a rm 250 motor. Bought the thing for $100 bucks, and did a rear brake job. That's pretty much it, had a few problems with the radiators on where to mount them. But after l ask some people on this site about it, problem solved.
Old Jul 24, 2003 | 12:33 PM
warrior86's Avatar
how much was your rear brake job and what exactly did you replace. This quad needs a rear brake job too and when i make some calls it came out to 4-500. This doesnt seem right. thanks
Old Jul 24, 2003 | 03:35 PM
lt230racer's Avatar
make sure it has the REAL slider pins on the caliper. this will let it adjust. someone put bolts in mine and i didnt realize it at first (DUH) because it wore the pads down in like a day cuz it couldnt adjust. Other than that it will fly. also get a prefilter and take your airbox lid off. you will have to rejet. mine with my lid off is the fourth clip down on the needle and a 128 main. 2 3/4 turns out. it will prolly be different on your friends, but it'll give you ballpark.
fd24
Jan 16, 2019 08:59 AM
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
