Piston & Compression
Old Jul 24, 2003 | 02:34 PM
bobk's Avatar
Default Piston & Compression
Just had both Hotcams & a 12.5:1 high compression piston installed on my z400. I'm told that the DRZ base gasket will raise my compression to about 13:1. What kind of problems will this high of compression create? Thanks in advance.
Old Jul 24, 2003 | 02:41 PM
roosthrower's Avatar
You're gonna have to run race gas with compression that high. I'm sure that you will have to replace pistons rings and gaskets alot more often than stock compression.
Old Jul 24, 2003 | 02:43 PM
Ellison's Avatar
Run a good race gas and there should be no worries.
Old Jul 24, 2003 | 04:49 PM
MOJAVE02's Avatar
as long as you run at least 100-105 octane gas you should be fine. remember detonation is the number one killer when running high compression. 13:1 isn't all that much so you shouldnt have to worry about many reliability issues. so good luck and run the right gas.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
