38mm on lt250r
Old Aug 27, 2003 | 11:30 PM
Binck's Avatar
Default 38mm on lt250r
I just picked up a mikuni TM 38mm flatslide that I am considering puting on my 86 lt250r. IS anyone else running one of these on their quadracer? What size jets are you using? Im sure Ill have problems fitting it in the intake boot as well, any suggestions? thanks ---Joe
Old Aug 28, 2003 | 12:54 AM
ShadyRascal's Avatar
My 39 PWK fits up all right. I run a 170 main right now if I remember right. I ride at 3600-5000' elevation. Mine's an 87 though, different than yours.
Old Aug 28, 2003 | 10:47 AM
Semms40oz's Avatar
i run a 38mm PJ, it fits but it is tight. as for jetting:
158 main
needle in the middle clip
62 pilot
Elevation: 700 - 1400 ft.
Old Aug 28, 2003 | 06:28 PM
Binck's Avatar
mikuni anyone??
Old Aug 28, 2003 | 07:05 PM
Semms40oz's Avatar
what did you run on you stock carb, it should have been a mikuni, i'd start with the same jets
Old Aug 28, 2003 | 07:09 PM
Binck's Avatar
the jetting will definately need to be richened up over my old carb due to more air flow, I am just trying to save alot of guess work by finding some one with the same mod.----Joe
Old Aug 29, 2003 | 12:25 AM
TomM's Avatar
I’d like that info too. I’ve got an extra carb for the LT500 that I’ve thought about putting on the 91 LT250 but I dont want to play with jetting forever to get it right again so I have not done it yet.
Old Sep 2, 2003 | 12:05 AM
Binck's Avatar
btt
Old Sep 2, 2003 | 01:13 PM
strokertwo's Avatar
Shady Rascal when running your 39 pwk did you use the stk air box? I have one on mine also had to use a K&N slip on becuase I could not get the stk air box to work carb is to big.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
mindcrime
May 9, 2000 02:43 PM
mindcrime
May 3, 2000 09:22 PM
fast-track-matt
Apr 23, 2000 11:10 PM
