03 eiger 4x4 trouble
Old Sep 1, 2003 | 02:57 PM
dakotajerry's Avatar
Default 03 eiger 4x4 trouble
I have an 03 eiger 4x4 manual shift. The bike has been awsome in every riding condition i have come to mud, snow water cutting trails in overgrown mountain woodlands ect. Is just started acting up though . it starts and idles fine but as soon as i give it some throttle it cuts out. If i partially obstruct the air intake snorkle it runs fine. If anyone out there has any input as to the cause of this I would greatly appreciate it. thanks
Old Sep 2, 2003 | 11:53 AM
Grizzjeeper's Avatar
Both of our eigers have done this. One had a piece of plastic floating around in the float bowl, two big to drain out had to take carb apart. Other one does it every now and then... It always comes out of it. nothing in the float bowl...
Old Sep 2, 2003 | 05:58 PM
joshpascoe's Avatar
I have two 2003 Eiger 4x4 with manuels shifts and they both also do this. What I have found to do is give the throttle very slowly and only open it up to about 1/4 throttle, then apply the choke to full. drive the Eiger like this until it warms up after that it should be fine. Both of my Eigers have been like that from the start. Hope that this helps.
Old Sep 2, 2003 | 08:55 PM
well i unhooked the carb from the head and breather and sprayed it down good with carb cleaner and drained the bowl and irrigated it throughly. seems to be running fine for now but who knows ive had it for 6 months before had any trouble
Old Sep 2, 2003 | 09:01 PM
Shortcut's Avatar
Make sure your airbox lid is tight and you dont have any suction leaks between the airbox and the carb.My wifes ozark did the same thing
after I cleaned the air filter one time until I figured out that I had'nt put the lid on right.
Old Sep 3, 2003 | 01:22 AM
JustMe's Avatar
Question:
Does water ever come into play prior to having this problem? The symptoms are almost textbook for having water in the bowl. Just wondering before I buy one of these things.
JustMe
Old Sep 3, 2003 | 01:31 AM
Water dosnt seem to be a factor ive had it in water up to the seat quite often and it never phases it
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
caveeagle
Sep 19, 2015 01:20 PM
