LT250R super lean when starting and idle
Old Sep 10, 2003 | 05:41 PM
f250r's Avatar
Default LT250R super lean when starting and idle
i have an lean problem that is haunting me! the bike has a 37.5 pilot jet, the clip is on 2nd down i mix my gas 32:1 should i get a bigger pilot or drop the needle to the 3rd down ? the bike will drive it self the idle is so high, oh and i have no air leaks the motor is brand new. FmF pipe, boysen reeds clamp on K&N, no air box my air screw or idle screw have no effect on it what so ever. so im sumped. help would be greatly appereciated !!!!!!! [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Sep 10, 2003 | 10:19 PM
ShadyRascal's Avatar
If your air screw and idle screw don't affect it you have passages plugged. Clean the carb real good, spray carb cleaner forced into all the passages and use compressed air to blow out, then start over. Your needle is for 1/4 or so throttle and up, it shouldn't affect idle, that'll be your pilot jet.
Old Sep 11, 2003 | 11:15 AM
f250r's Avatar
Thanks ill try that, but the carb has a 37.5 stock pilot in it and it blows smoke really bad so i cant go up can i?
Old Sep 11, 2003 | 11:48 AM
I would lay money something's just goofy inside your carb. Even with a lean pilot jet it shouldn't be that bad, just my opinion.
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
sticky123
Jun 14, 2015 07:36 AM
Big600twin
Jun 10, 2015 03:01 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
