Eiger Shift Problem
Old Oct 4, 2003 | 09:49 AM
bushweasel's Avatar
Default Eiger Shift Problem
I have a new Eiger Auto thats often tough to shift into Low & when shifting from low to high
It often doesn't kick into high until the machine moves a few feet.
Dealer adjusted but results are about the same. He suggested shifting to Neutral 1st
instead of going direct from high to Low.
Its a new machine. Any ideas or suggestions ?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 14, 2003 | 06:40 PM
EigerSlider's Avatar
Obvious question:
Are you coming to a complete stop before you try to shift from high to low?
The Eiger will not go into low from high without first coming to a complete stop and by holding the rear brake on (hand brake not the foot brake). Also running at full choke during initial startup will cause the engine to run fast which seems to affect my ability to go into any gear other than Neutral until the engine warms up enough for me to reduce the choke to at least half before I can shift.
baysport
Jul 23, 2015 11:37 AM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
