lt230s
Old Nov 17, 2003 | 06:25 AM
  #61
MBrooks420's Avatar
Default lt230s
Yeah, I'm sure the dealer can both bore and hone. You may want to flip through the phone book and see if there is an independant ATV repair shop. I have 2 in the area that are very good. I bet there is a cheaper/better place to have work done, especially if you aren't using factory components. I've had trouble with the Suzuki dealer here refusing to put in aftermarket parts(I assume because I didn't buy them there) A bore at my shop runs $40 for a single cylinder and a honing is $15.
Old Nov 17, 2003 | 03:58 PM
  #62
Vinson581's Avatar
Default lt230s
grate thanks mbrooks
Old Nov 18, 2003 | 03:06 PM
  #63
BigBearFX's Avatar
Default lt230s
bad bearings would slow it down?
Old Nov 19, 2003 | 10:43 AM
  #64
Airman88's Avatar
Default lt230s
i got them (hubs) froma '87 and you might need about 4 1/2 washers to put on the inside and outside of the hub or it will be loose
Old Nov 19, 2003 | 03:40 PM
  #65
Vinson581's Avatar
Default lt230s
i got the thing pulled apart mbrooks and i found the exhaust port gummed, mabey i wll take a pic. but the cyclinder is good and the rings look bad.
Old Nov 19, 2003 | 05:26 PM
  #66
MBrooks420's Avatar
Default lt230s
If the cylinder isn't scored, then a hone should take it back to new condition. How do the valves look? If everything else looks ok a new set of rings may be all you need.
Old Nov 19, 2003 | 05:47 PM
  #67
Vinson581's Avatar
Default lt230s
the engine valves are sHot and i have a whole new head so that will take care of that problem. could it be smokeing because of the valves?
Old Nov 19, 2003 | 05:48 PM
  #68
Vinson581's Avatar
Default lt230s
the valves on the other head i forgot to say are brand new
Old Nov 19, 2003 | 07:08 PM
  #69
MBrooks420's Avatar
Default lt230s
Bad valves can definately make a motor smoke.
Old Nov 19, 2003 | 07:57 PM
  #70
Vinson581's Avatar
Default lt230s
ok thanks how bout hard to start?
