lt230s
Old Nov 16, 2003 | 11:35 AM
  #41
Vinson581's Avatar
Default lt230s
ok i have an 89 lt230E how do you adjust the clutch? the motor does not tick or knock. the smoke is blue(oil) smokes the same no matter what temp. and no to the starter pull. the motor still runs, but won't idle, need to adjust the idle, how do you do this?
so you are saying just replace the rings? and not the piston? i thought i should just get a weisco comploeat package for 70 bucks. i assume the motor will need to be retimed?
vinson581
Old Nov 16, 2003 | 11:49 AM
  #42
MBrooks420's Avatar
Default lt230s
You adjust the clutch by removing the oil sight glass, and ajusting the valve style screw/nut.
::RIGHT OUT OF THE FACTORY MANUAL::
1. Drain engine oil.
2. Remove 3 bolts and take of clutch adjustment cap(sight glass)
3. Loosen the locknut.
4. First tighten the release screw(flat head) 1/2 turn, then back off until resistance is felt.
5. From that position, tighten the release screw from 0-1/8 turn, then tighten the locknut.
6. Install new gasket and clutch adjustment cap.
7. Refill with proper oil.
If you are willing to spend the cash I'd go ahead and do a complete top end. It will ensure a motor you wont have to take apart again. If it doesn't try and rip the starter out of your hand every few pulls its low on compression. You may want to consider a higher compression piston, or having the head shaved(milled)
Old Nov 16, 2003 | 04:30 PM
  #43
Vinson581's Avatar
Default lt230s
i just really want to do it as low cost as possible since i only spent 500 bucks on the engine and bike. do you think i can go ahead and buy the weisco piston package? it's high comp. and i am going to have a friend mechanic check the valve seals and borrow a timing light from a german import bmw dealer i know, do you think the motor will stop smokeing if i get the piston and assc. done? and get the valve seals done?
nobody will answer my question and it's a good one, being there is a timing chain will i need to get it retimed????
Old Nov 16, 2003 | 05:42 PM
  #44
MBrooks420's Avatar
Default lt230s
I'm sure the bike could use a fresh top end, and a higher comp. piston will increase performance. You may have to run higher octane fuel however.
Old Nov 16, 2003 | 05:43 PM
  #45
Vinson581's Avatar
Default lt230s
um like what 93 octane? when you said you could "help me out what did you mean?
Old Nov 16, 2003 | 05:47 PM
  #46
MBrooks420's Avatar
Default lt230s
I meant if there is something you get stuck on I could probably help figure it out.
Old Nov 16, 2003 | 05:48 PM
  #47
Vinson581's Avatar
Default lt230s
oh thanks, i think i am going to go and order the piston and stuff and get the valves looked at and then get a new top end gasket set and get the motor retimed
Old Nov 16, 2003 | 07:14 PM
  #48
MBrooks420's Avatar
Default lt230s
Oh, and I'm sure 93 would be plenty high.
Old Nov 16, 2003 | 08:19 PM
  #49
Vinson581's Avatar
Default lt230s
ok thanks man i will let you know how i make out.
oh the one question nobody i have asked will answer is (being there is a timing chain just like a car will the motor need to be retimed after it is taking apart?
Old Nov 16, 2003 | 08:22 PM
  #50
MBrooks420's Avatar
Default lt230s
Yeah, since it is an overhead cam, and the cam and cam chain will need removed.
