lt230s
Old Nov 16, 2003 | 08:24 PM
  #51
Vinson581's Avatar
Default lt230s
do i need a timing light to do this?
Old Nov 16, 2003 | 08:32 PM
  #52
MBrooks420's Avatar
Default lt230s
No, it's very simple. You remove the timing plug(by the recoil starter) and set the motor up to TDC on the compression stroke. Then you turn the cam sprocket to a certain position, and it is set. I can either scan or take a digital pic of the manual page that describes it tomorrow.
Old Nov 16, 2003 | 08:52 PM
  #53
Vinson581's Avatar
Default lt230s
k thanks
Old Nov 16, 2003 | 08:55 PM
  #54
MBrooks420's Avatar
Default lt230s
Here is an LA sleeve stoc bore on E-bay you may want to watch. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2443073290
Old Nov 16, 2003 | 08:59 PM
  #55
Vinson581's Avatar
Default lt230s
willl i need to resleave the cyclinder
Old Nov 16, 2003 | 09:04 PM
  #56
MBrooks420's Avatar
Default lt230s
No, you can either sleeve, bore or hone it. I doubt the cylinder will need more than .010 or .020 bore to clean it all up. Unless it has been bored before. This is all hypothetical at this point. It may only need a hone and rings, and maybe not even that. It may be as simple as a valve job.
Old Nov 16, 2003 | 09:11 PM
  #57
Vinson581's Avatar
Default lt230s
is honeing roundind the cylinder?
Old Nov 16, 2003 | 09:22 PM
  #58
MBrooks420's Avatar
Default lt230s
A hone cleans up the light scratches and gives the cylinder a crosshatched pattern that the new rings need.
Old Nov 16, 2003 | 09:32 PM
  #59
Vinson581's Avatar
Default lt230s
can i get this done at my dealer and if so how much?
Old Nov 16, 2003 | 10:11 PM
  #60
suzukiatvrider4's Avatar
Default lt230s
heyairman88 what year of banshee did you get your hubs from
[img]i/expressions/face-icon-small-smile.gif[/img]
