Has anyone Yosh'ed thier Z250 yet ??
I asked the same question and all I got was memorized statements. I understand how engines work. In my experience, the way to HP is intake, porting and pipe. The bottom line is a pipe alone might let your engine develope more power at lower RPM, but to see real gains you have to do all 3 mods.
I'm thinking the Z250 and the Ozark use the same engine so maybe that pipe will fit my 03 Ozark. What do you think?
Dan308
Dan308
Originally posted by: hajimoto684
The Z has 30% more power than a Ozark, read that somewhere.
Suzuki Ozark 250 Specifications
Suzuki Ozark 250 MSRP*: $3,499
Engine: 246cc, 4-stroke, single-cylinder, air-cooled, SOHC, 2-valve, TSCC
Bore & Stroke: 66.0 x 72mm
Compression Ratio: 9.2:1
Carburetor: Mikuni™ BS29
Lubrication: Wet-sump
Ignition: Digital/transistorized
Starter: Electric/recoil
Ozark 250 Transmission: 5-speed with reverse, automatic clutch, 2WD
Ozark 250 Final Drive: Shaft
Suzuki QUADSPORT 250 Specifications
Suzuki QUADSPORT 250 MSRP: $3,899
Engine: 246cc, 4-stroke, single-cylinder, air-cooled, SOHC, 2-valve, TDCC
Warranty:
Compression ratio: 9.2:1
Fuel System: MikuniBSR29
Lubrication: Wet Sump
QUADSPORT 250 Transmission: 5-speed with reverse, automatic clutch
QUADSPORT 250 Final Drive: Shaft
Dan308
