1988 QUADRACER LEAKING @ Water Pump
Recently my quadracer has started to develop a small coolant leak coming from the small hole under the waterpump on the right side of the quad. Is this the waterpump mechanical seal? How involved is replacing this? Can I just pop off the water pump cover and access this part or does it require removing the case side? any input or suggestions would be greatly appreciated.
-BEN
-BEN
If it is a small leak, try the Bar or Bars Leak stopper stuff. The Clymer manul says to add it to your coolant every time you change it. Run if for a while after you add it. It worked like a charm for us, and is definitley worth trying before you dig into the water pump.
Hankey Pankey
07-31-2015 05:50 PM
