need to jet for hotcams?
Old Jan 22, 2004 | 02:27 PM
Blaster2fast's Avatar
Default need to jet for hotcams?
i was planning on after i get my shocks and axle and wheels all installed and stuff on buying some hotcams.. the base gasket and the drze springs and a CDI unit.. a uni filter and romoving the lid... do i need to rejet ? i know i do for the filter and stuff but what about the hotcams? does a jet kit come with all the jets i will need? after i get my motor done... THEN i am purchasing my pipe.
Old Jan 22, 2004 | 04:28 PM
rede34m5's Avatar
you should probably re-jet. most people say to re-jet after airfilter mod and especially a pipe. when ever you improve its breathing a re-jet may be needed.
Old Jan 22, 2004 | 04:51 PM
Quadfather's Avatar
No jetting changes are needed for a cam.
Old Jan 22, 2004 | 05:30 PM
MBrooks420's Avatar
I'd rejet after the cam due to the fact that a longer duration, and a better breathing filter will allow more gasses in and out of the cylinder.
Old Jan 22, 2004 | 05:41 PM
Vinson581's Avatar
the cam is going to make the motor run different, the exhaust, and intake, and combustion strokes will all take places at different times, and in order to do this the motor needs enough fuel and air to make up for the change in combustion pattern.
Old Jan 22, 2004 | 05:47 PM
LT250Rodney's Avatar
The strokes take place at the EXACT same time, the VALVES will be opening differently. Either opening more, staying open longer, or both. I'd say jetting would be necesary since you added the filter.
Cole Hadden
Jun 15, 2025 09:05 AM
Pinkster660R
Jun 24, 2003 10:37 AM
thor440
Apr 29, 2003 11:50 PM
slappie
Apr 24, 2003 10:51 AM
Chimmer
Sep 18, 2002 09:45 PM
