crankcase full of gas
Old Feb 5, 2004 | 08:26 PM
jamieyz250's Avatar
Default crankcase full of gas
i have a quadrunner 4x4 that is filling the crank case with gas runs fine no smoke. the crankcase vent hose is blowing gas into the airbox . I have never seen anything like this please help
[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 5, 2004 | 09:53 PM
macgiver's Avatar
does it happen after you tow it on a trailer. i ask because i had that problem with a tag along cement mixer. i quess the float bounces around, dumping the fuel in the bowl into the crank case. to stop this i would turn off the fuel, and let it run till it used up the fuel in the bowl. or maybe you have a sinking float. just my 2 cents.
Old Feb 5, 2004 | 10:14 PM
jamieyz250's Avatar
thanks for your help . it dosent matter if you haul it or your just ridding . change the oil start riding 20 maybe 30 min. later crankcase is full gas tank is empty[img]i/expressions/face-icon-small-frown.gif[/img]
Old Feb 5, 2004 | 10:37 PM
Mars's Avatar
Turn your fuel petcock to off.
Most likely: carb float stuck open. Carb fills with gas: carb is tilted towards engine: gas flows into intake: one valve is open:
Pull carb or at least float bowl and clean it out. Make sure float is not full of gas.
Also possible. If you have a vacumm type petcock: vacumm diaphram has hole in it. Vac line is connected to intake manifold: tank drains into intake... into the engine.
Old Feb 6, 2004 | 12:59 AM
KFXBob's Avatar
Check the fuel valve(petcock), if it has a fuel line to the carb and a smaller line to the intake side of the carb, thats probably where the problem is, if not then the float is stuck open, a piece of dirt or other debris is holding it open, BUT that usually makes it rich and smoke and smell like fuel out of the pipe. Also it should have a overflow tube out of the carb and fuel will spill out of it if the float is stuck.
Good Luck
Bob J
Johnny Mac
Aug 15, 2019 03:13 PM
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 30, 2015 04:27 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
