1 front wheel leans in the other is straight (chamber) Z400 stock A arms,why? what can I do/check?
Old 02-05-2004, 10:03 PM
JOEYG's Avatar
Default 1 front wheel leans in the other is straight (chamber) Z400 stock A arms,why? what can I do/check?
Hi I just noticed that my right tire (sitting on the quad) is titled in more then my left tire which is straight, it is not much but it is noticable, what can I check to see if anything is bent? I don't think it is but I am not sure. thanks
Old 02-05-2004, 10:25 PM
Mars's Avatar
Hummmm. Maybe: frame bent, A arm bent. Most likely upper A arm bushings worn out.
Old 02-05-2004, 10:35 PM
JOEYG's Avatar
How would I check them?
Old 02-05-2004, 11:02 PM
Slacker1bob's Avatar
Take measurmenst from various spots. So many things could be bent. Like from frame to ball joints, ball joints to eadge of rim, etc
Old 02-05-2004, 11:15 PM
Mars's Avatar
Look for wrinkled paint on the frame. Check angles/spaces between frame tubes. Compair your left and right A arms. Lift the front end and see if the A arms wobble at the piviot pionts on the frame.
KimSJoh
14
07-18-2015 07:20 PM
jettman
07-06-2015 12:16 PM
J-Mack
Polaris Side by Sides
07-04-2015 04:19 PM
yambam13
07-04-2015 01:49 PM
Mphillips
07-02-2015 07:20 PM
Quick Reply: 1 front wheel leans in the other is straight (chamber) Z400 stock A arms,why? what can I do/check?
