eiger problems
Old Feb 29, 2004 | 08:22 PM
mikee2's Avatar
Default eiger problems
I went out and started riding the eiger today and had a few problems. I filled it up with gas the other day and it runs fine with the choke on but if you take the choke off it will run rough,backfire,and die. It will run with the choke on but will miss here and there. I drained the gas out of the tank and went to the store and got new 93 octane and put a new plug in also but it still does it. Anyone know what may be wrong. I thought there may be something in the carb. What do you all think.
Old Feb 29, 2004 | 08:44 PM
Tmac's Avatar
Try cleaning your carb?
Old Mar 1, 2004 | 03:05 AM
hondabuster's Avatar
Sounds like your pilot jet has a blockage, the jet has a very tiny hole, that runs thru it, and easily plugs up.Try carb cleaner, and compressed air to clean it out. Sometimes it takes a very small soft(copper) wire to push it out.
this article may help
carb cleaning
Old Mar 1, 2004 | 09:21 AM
MuddyEiger's Avatar
Definitely clean the carb (I had crap in there from the factory). I would suggest an inline fuel filter too.
Old Mar 1, 2004 | 11:51 AM
eiger2's Avatar
Mikee2, unfortunately this is the Eigers biggest stumbling block. When new they all seem to do this. Plastic in the tank somehow gumms up the works and you have the trouble you are having now. The solution is simple. Clean your entire fuel system and jets, install an in line fuel filter. Go ride with pride!!!!
PS since you are prolly a new Eiger owner, I would suggest a service manual, and a bunch of those little rivets that hold your plastics together (about a $1 cheaper for the Honda version).
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
baysport
Jul 23, 2015 11:37 AM
hondarider1234
Jul 21, 2015 11:53 PM
