Reed stops - Quadzilla
Old Mar 13, 2004 | 04:26 PM
truckracer's Avatar
Default Reed stops - Quadzilla
My reed stops were removed by a previous owner. What effect do you think this has on performance?
Old Mar 13, 2004 | 04:51 PM
lt500abuser's Avatar
not a problem unless your throttle get's stuck wide open.aftermarket reedvalve's don't have them.i've been running my stock reedcage with boyesen reeds and no limiter's with no problem's.my fmf reedcage fell apart after a few year's,my v-force reedcage has some prob' with breaking the reed's maybe it's to good of a seal.my stock cage has alway's worked without a problem.
Old Mar 17, 2004 | 10:44 AM
truckracer's Avatar
bump....
Old Mar 18, 2004 | 10:03 AM
ZigZilla's Avatar
Is it a stock reed valve?
V-force reed valses do have reed stops and you must use them.
Stock Reed valse stops should be used also , without them you will reduce the life of your reeds and increase the chances of reeds cracking or breaking.
Old Mar 18, 2004 | 12:22 PM
Duneaddict's Avatar
Well said Zig... Shortens the life of the reed... If you really want to be picky, trim 3mm off the entire length of each reed stop, use a 3/8 reed spacer, and spread the reed stops so the cage will barely fit inside the cylinder...
Use a good quality reed petal (Carbon fiber or stocker) not any dual stage B.S. and run it!
The spacer and trim work will unblock part of the boost port, therefore improving flow.
Just my $.02
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
tysonbully
Sep 28, 2015 02:30 AM
Levi Enstad
Sep 26, 2015 05:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
