eiger fuel filter
I've seen alot of talk about a fuel filter for eiger's. It sounds like a good idea on any quad. I'm going by the dealer tomorrow so i think i'll pick one up. Where's the best place to put it, as far as access goes? Do you need to remove a portion of the hose or can you make it fit without removing any hose? Also when you cut the hose, won't fuel run out? Stupid question i know!
You're kind of limited as to the where, you cut into the line that comes from the tank, but it is pretty easy to access in there. I used a small clamp to pinch off the line so it wouldn't run. You'll still leak a little when you first cut so have a rag ready.
Muddy Eiger,
On the fuel line, what is the diameter? Without seeing it I am guessing 5/16???... I know the fuel filter companies make their units with different diameter barbs. Any input would be great.
I do not have the Eiger handy to look but want to buy filter and install this weekend when I get to where it is.
Thanks
Thanks
I'm going to the dealer tomorrow morning to pick up part's i ordered and a fuel filter. I'll post the size info when i get back from afternoon ride. Thanks for everybody's input. It seems like the companies should go ahead and include a fuel filter on all bikes.
