found eiger power outlet limit
Old Mar 16, 2004 | 04:11 PM
eiger2's Avatar
Default found eiger power outlet limit
I had my aux lights (55 watt ea), my heated grips (not sure how much power or if on high), And blew the horn a couple times. The fuse blew. The grips or the lights need to be on their own curcuit since they ar on together most of the time.
Old Mar 17, 2004 | 11:47 AM
aksafari's Avatar
HORN?!? not one of those OOOGAAAHHH horns I hope.
Old Mar 17, 2004 | 12:19 PM
Vinson581's Avatar
my vinson has had alot of power problems, that i have rendered all of them.
for my power:
110wx2 center lights in the grille.
the stock 2 head lights
a 100w in the 3rd head light
60w back up light.
heated grips
battery that barely fits under the seat, but damn do i get alot of cold cranking amps.
i gotta get that start in gear thingy fixed.
i ran heavy duty wireing throughout the bike, to the main power supply, with a 4ow main fuse,
my power problems were so bad that the dash would flicker as well as the head lights, and all the little idiot lights on the dash.
v581
, never had anything on the power outlet tho, gotta try that 1.
Old Mar 17, 2004 | 03:44 PM
eiger2's Avatar
the horn is a stock GM off an s10. You wont believe how handy it is. When we ride in a group I either lead or follow the entire pack. In front its unneeded, but bringing up the rear it comes in handy if I see someone in a bad situation or if Im in a bad spot.
I'm thinking about getting an air horn from harbor frate. Then tap into the air line and have an on board compressor. $15 [img]i/expressions/face-icon-small-smile.gif[/img]
I'm wiring up my winch today, so theres more power. I'm thinking about adding a radio to the box Im building for the front rack.
I have 2 55 watters on the back for towing duties and I added a trailer plug so the lights on the trailer work when I tow it around.
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
Ramman1
Jun 16, 2016 09:07 PM
Unzzy66
Jul 11, 2015 10:01 PM
tweeder
Jul 5, 2015 01:57 PM
