Everybody Please LOOK HELP ME I WANT TO RIDE again!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 18, 2000 | 01:11 AM
iwana400ex's Avatar
ok i broke my clutch cable so i had to ride my lt250r home with no clutch i went out bought a new clutch cable put it on clutch doesnt work still in gear when i pull in the clutch so i adjust it and adjust untill i cant anymore,still doesnt work what could it be could you tell me how to fix it ive only had this quad for 3 days somebody please help me it kills me to get a call from one of my friends and he wants to go riding and i cant help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 18, 2000 | 09:17 AM
Tree Farmer's Avatar
Can't shift your quad OR your keyboard, eh, iwana400ex? Sorry, couldn't resist; my comment relates to your use of all lower-case letters (preferable to all CAPITAL letters, anyway).
Now, about that clutch. I've been flamed before for a similar post, but: I don't have enough detailed information to offer any constructive advice. Maybe other readers can diagnose your problem from the info you provide.
When you had the case cover off to replace the cable, the clutch release mechanism was visible; you could manipulate it to see if it allowed the clutch discs to separate. If the release mechanism works, and the cable is the proper length, and the steel clutch discs aren't so warped they can't disengage, your problem's not obvious to me.
A service manual, or at least a peek at the exploded parts diagram at your dealer's, might be useful to you. (I realize I'm NOT very useful, maybe another poster will be.) Good luck.
Tree Farmer
Old Jul 18, 2000 | 10:37 AM
ridzhard's Avatar
Without being able to see the machine, I cannot give you an accurate diagnosis. Manual clutch's always have a little drag to them. Especially when the oil is not warmed up. Example, before you ride your quad in the morning, if it is in gear and you pull the clutch in it still will not roll. I would suggest that you take the machine out of gear. Adjust the clutch for proper free-play and start it up. Let it get warmed up, and then give it a try. Hope this helps.
Old Jul 18, 2000 | 02:40 PM
iwana400ex's Avatar
thanks but before i read your post i went and took it apart i found out its the clutch basket the tabs on the clutch plates notched it out clutch baskets are expensive!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !i think im going to get a used one thanks
Nondem
Feb 22, 2020 12:20 PM
HondaR24
Jul 16, 2015 10:45 AM
honda71
Jul 12, 2015 05:56 AM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
honda71
Jul 8, 2015 02:13 AM
