Snowplows and ground clearence
Old Apr 17, 2004 | 02:55 PM
snowtoys's Avatar
Default Snowplows and ground clearence
Hi all,
I am comparing notes on snow plows. What I want to know is with the blade on the ground, how much clearence do you have from the bottom of the push bars to the ground and also the mounting height where it attatches to the atv. Please state the brand name of the plow.
What I am investigating is if I have something bent I can't find. I have compared my dimensions to a new plow of the same brand but didn't find any diffrences.
What I see that is annoying while plowing is the rub marks in the snow from the push bars. if I go over a bump the blade lifs a bit and doesn't cut the snow to the bottom. More clearence on the push bars would fix this problem. The wear bar on the blade still measures 2".
If you have a better plow than the Warn I am interested in learning your thoughts.
Thanks
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
kampswas
Sep 23, 2015 05:05 AM
