Powervalve disconnect?
well i took my head off today.seems the rings came apart and got lodged between the piston and cylinder.needs new rings,bore and maby a piston.how do you disconnect the powervalve?also it put a good goudge in the head on the very edge.will that hurt it or do i need a new head?how much can the head be shaved down?
If you mean so you can take the cylinder off.....
Remove the 4 bolts on the inspection window (above water pump)
Use needle nose pliers to unhook the plastic clip-thingy
And pull the rod out of the lever.......
Get a big peice of sandpaper (maybe 180 grit-ish?) and set it on a flat surface and rub the head back and forth acrossed it. That might help take care of your gouge.
I just noticed you had a 250, although it should be the same as the 500......
exmotocrosser
Sep 13, 2019 06:12 AM
