Which two-stroke to buy??
Old Apr 19, 2004 | 11:16 AM
Linz's Avatar
Default Which two-stroke to buy??
If you're going two stroke get a Yamaha Banshee dude! You'll never regret it! i recon it is the most awsome two stroke out there!
Old Apr 19, 2004 | 12:47 PM
QuadSportFreak's Avatar
should just be able to pull the side cover, pop the new seal in, an put it back together. you may need to add oil after you do this, or if your antifreeze/coolant goes through that side cover, fill your coolant up.
Old Apr 20, 2004 | 10:29 PM
Canadianrider's Avatar
Well folks thanks for the advice. I am buying the 1992 lt250r. Its in much better shape (except fadded plastics) paying $2400 CDN
The guy with the trx250r decided he is going to sell it on ebay, so i said good luck with that and walked away.
Ok I gots a question for you guys now. Had the quad running, and heard a minor tinging noise comming from the engine. Is this normal for a 2stroke quad? (not that loud)
I am used to sleds, but new to two stroke singles. Any input would be appreciated.
Old Apr 20, 2004 | 10:36 PM
needaR's Avatar
Good choice!!does it do it in a pattern like one after another?mine does this but its at random times.my friends blaster does this alot.
Old Apr 20, 2004 | 11:26 PM
  #15
CapnMorgan's Avatar
LTs make a weird pinging noise when they run. I've had three and they all did it. My current LT is new from bottom to top end ( rod, Crank, Bearings, Piston, etc...) and makes this noise. But a worn clutch basket will make a rattling noise, Not a bad thing but can be anoying and will need replaced eventually.
The LT was a good choice, I think they make a much better woods bike than a honda. They have more low end torque due to the power valve, they are wider and more stable, Have a larger more comfortable seat, and are cheaper to fix when you have to buy parts.
Old Apr 21, 2004 | 01:05 AM
  #16
LT249r's Avatar
i would go for the LT250r, not only that is is newer, but like <FONT face=Verdana size=1>QuadSportFreak says, all the bugs are worked out and is better. I am no expert but i think the LT is faster tha the TRX. If only the back tires are bald, that can mean 2 things, the owner wraps the ShIz-NuTs out of that motor which is not good, or he like to power slide a lot![img]i/expressions/face-icon-small-cool.gif[/img] All in all, all you need is a weekend and some sand paper and polish and that thing will be PERFECT! If you get the LT and decide to sand the rust off, buy sand paper 80 and sand with 80 grade first then move to 220 grade and then paint it, it will be brand new.
By the way, just about all LT250r's are only worth 2500 or less, for 92 and down, they can't be worth more than that unless they have a shiz-nut load of after market parts. </FONT>
Old Apr 21, 2004 | 03:42 AM
  #17
Linz's Avatar
Get some plastic renew for your plastics it works miracles. You can get it for $15.00 at www.rockymountainatv.com
www.e-dirt.co.za/
HUEDOGG
Jun 18, 2003 08:11 PM
HUEDOGG
Sport Quads
13
Jun 6, 2003 06:27 PM
Thor
Jul 19, 2002 08:28 PM
sknaus
Apr 1, 2002 11:27 AM
Tyson
Feb 28, 2002 07:46 PM
