Manual Cam Chain Tensioner , I need install info and adjusting info Z 400.
Old May 4, 2004 | 07:46 AM
JOEYG's Avatar
Default Manual Cam Chain Tensioner , I need install info and adjusting info Z 400.
I have a Z 400 and I was going to order a manual one from http://www.hayabusazone.com/tensioner.html
hayabusazone
I was wondering if this is the one I need, and how do I install it?
How do I adjust it?
and how do I know when I need to re adjust it?
and any other info you have this is for a 03 Z 400 thanks a lot
Old May 4, 2004 | 08:19 AM
z838mx's Avatar
why not just keep the one that is simple and easy to uea? The one that came with your machine go bad? I would stay with one like the stock one that adjusts itself.
Old May 5, 2004 | 08:00 AM
JOEYG's Avatar
Anyone else?
Old May 12, 2004 | 07:56 AM
JOEYG's Avatar
Please keep it coming.
Old Mar 22, 2005 | 05:29 PM
03hmfz's Avatar
bump
Old Mar 22, 2005 | 06:27 PM
rolsmojave3's Avatar
put it on..then tighten it till it's tight..hmm...donno how tight though...till the chain doesn't chatter
Old Mar 22, 2005 | 08:46 PM
MURDR's Avatar
You dont want to use the manual chain tensioner. i have the hybusa chain tensioner and i bent two titanium valves because it was to tight. So your better off going with the stock unit. Even yoshi told me the same thing.
Old Mar 23, 2005 | 01:22 AM
MeIsCheech's Avatar
If U want the manual tensioner because Ur cam chain has stretched, change that chain, don't try extending its life or U will have more probs then just the stretched chain. Like Murdr says I havn't heard of anyone who could exactly tell if the tensioner was too tight or not. I got my cam chain from Advantage Cycle for $60. It is a 3/4 heavy duty DID, don't get the 4/5 it rides on top of Ur guides on in them.
95wolv
Jul 17, 2015 08:13 PM
xbin87116
Jul 13, 2015 02:10 PM
John Boy
Jul 13, 2015 11:16 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
