Eiger just stops
Old May 17, 2004 | 08:29 PM
rolsmojave3's Avatar
Default Eiger just stops
yeah i have an Eiger with about 950 Miles on it and yesterday when riding it just started to sputter and wouldn't drive at over half throttle with out the choke on!!! I don't think it was outta gas or starved because the fuel filter was full of gas and it wouldnt run for about another half hour or so Only time it has done it
oh add on that I read all of this and put on the fuel filter within the first 2 hours
any thoughts apprectiated
Old May 18, 2004 | 01:44 PM
eiger2's Avatar
Carb dirt. Try taking out the air filter and put your hand over the intake a couple times til it stalls. Run up the RPMs a little. Otherwise you need to check the vent hose from the carb to under the seat or take off the bowl and clean the jets.
Old May 18, 2004 | 04:40 PM
hondabuster's Avatar
Sounds like the carb will need to come out for a cleaning and checking. Something went lean, needle clip came off, needle broke, jet is plugged....
By turning on the choke, you added more fuel, via the starter jet... good thinking.
Old May 22, 2004 | 02:26 PM
thanks did all you said and now it runs like a champ
Johnny Mac
Aug 15, 2019 03:13 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
tysonbully
Sep 28, 2015 02:30 AM
Jackg17
Sep 26, 2015 09:30 PM
