Wont kick over
Old Jun 5, 2004 | 08:23 PM
kilaan's Avatar
Default Wont kick over
Just bought a quad, was running great a couple days ago. Tried to start it yesterday no go. Checked the gas, it was empty. Went out and bought some 2 cycle oil and mixed it 50:1 (was just told today, it should be 40 to one from now on). Still no go. Bought a spark plug and it still wont kick over.
New to the whole ATV thing and am trying to learn how to work on them.
Its a 1986 Suziki 250R
Old Jun 5, 2004 | 10:39 PM
BIGGONE's Avatar
Hey there!
Sounds like some simple things for you to check & correct.
Drain that gas and put the right mix in # 1.
are you using the choke? Most common problem, is your switch in the "ON" position?
or if it's a kill switch is it connected right?
are you getting spark? are you using the proper size plug, maybe run one a size hotter.
Hope this helps you get back on track!
Old Jun 6, 2004 | 11:46 AM
Billqdracer's Avatar
if youe quadracer will not physically kick over i bet your thrust washers on the sides of your piston broke and caused it to lock up. i had two do this already a 85 and a 87 quadracer. it is a common problem.
Old Jun 6, 2004 | 02:41 PM
needaR's Avatar
Billqdracer-did you put thrust washers back in?i didnt and my LT is holding up fine.seems to run great.
Old Jun 6, 2004 | 09:41 PM
kilaan's Avatar
Well i figured out the problem.... told you i was new to this stuff......
The float was stuck and the night previous i accidentally left the gas on for a few hours.
Took about 20 minutes to get all the gas out of the carb and exhaust it was so flooded.
Old Jun 6, 2004 | 09:50 PM
needar yes i did put them back in and mine are running great. I would be afraid of my bottom bearing wearing without them from side movement.
buddieboy
Dec 9, 2016 05:50 PM
Clint Russell
Sep 25, 2015 03:20 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Tim Shoe
Sep 7, 2015 12:15 PM
