38mm carb for 36, any takers?
#31
here;s a stupid question, but i want to buy a motion pro twist throttle, is there a special cable I would have to buy for my new carb, or would the one they send work, or should I use the one the guy is sending me with the carb, o ya, tracking number says it should come monday.
#32
Dude,
Twist throttle is another topic. If you like riding with one hand behind your back go for it. Otherwise DONT go twist grip.
In time your thumb muscles will develope and your thumb will not get sore anymore. Twist grips are dangerous on a Quad, You will gas it when you dont want to, then your body and Quad will be way more sore than your thumb ever was!!!!!!!
Just my .02
Dont say nobody warned you before you installed it and busted yourself and your quad up.
Just my .02
#33
#34
Time will tell on that one Shon. If tis what you are comfortable with dont change. If you and I went way back, I'd be slashing your tires every time you tried to ride it. Nothing personal, I just dont want to see another rider busted up like that due to a twist grip. You know the story.
#35
#36
#38
The Gas Gas Wild 300 and 450 come with twist. When I first put my twist on my 250R I hit a whoop and sailed off into some bushes. Twists can be dangerous and you have to MASTER a twist throttle, not just be comfortable with it. But if you can master it you will have an advantage over other riders.
#39
#40
