Just lost king quad in 6 feet of water
How long was it in the water?
You might want to check the wheel bearings. Basically lubricate everything that can be lubricated.
Ask yourself, what would the service people do that you haven't already done yourself. If you know what it is you can just do it.
You may want to inspect the ignition components and anything else electrical to prevent future corrosion.
I was riding down an old powerline when the trail turned into a swampy area. I kept on the trail because the water was only a foot deep. I followed this for about a hundred yards then all of a sudden I fell into a hole and was neck deep in water. No warning, the ground just fell out from underneath me. Luckily I was near a power pole and able to winch out. trail was only 5 ft wide. I was also lucky enough to run into someone
on the trail who was able to tow me back to the truck. As for the quad it seems to be running fine. Im gonna change the oil and filter again just to make sure all the water is out of there.
Wow! Mean trail. I done that to an old 230 Quad once and it took and hour to get it going ... no one there to tow me and five miles of narrow trail from my truck!
Last year I buried a GMC Jimmy in a river. It didn't look deep, but it was deep enough the current pushed the front around sideways ... got some pics of it somewhere. Anyway everything electronic on that thing had to be gone over the last year. I suggest you pull connections apart and dry them out and put some waterproof grease on them ... only after they are dry though. Also WD 40 is known to be good for drawing moisture out of things. Maybe spraying it down with that would correct some future corrosion. I use grease and then spray the whole wiring harness down with ignition spray a couple times a year, or more and so far no corrosion. Good luck.
