Eiger Died
Old Jun 21, 2004 | 09:17 AM
MuddyEiger's Avatar
Default Eiger Died
Happened to me too! My problem was crap in the carb.
Old Jun 23, 2004 | 07:11 AM
z400nora10's Avatar
Default Eiger Died
I had the sampe kind of problem with my z400. a had a bit of backfire, splutering engine and and engine cut out once and a while.
It was all due to a lack of fuel in the tank... try that and see what happens. if you havnt already
Old Jun 23, 2004 | 01:57 PM
eigerbever's Avatar
Default Eiger Died
I had the same problem, checked plug checked float bowl. It turned out, not enough gas in tank. Remember the Eiger main fuel pickup tube sits high in the tank. Because mine would only sputter and backfire, and stall with the petcock in the ON position, when in RES or PRI it would run fine
Old Jun 24, 2004 | 01:25 AM
FrozenNorth's Avatar
Default Eiger Died
Thanks for all the info guys. I had fuel in the tank, that was not a problem. The carb had come unseated from one of the couplings it rides in. This allowed for a lean mix accounting for the sputtering and backfire. Evidently the last backfire caused enough of a gab that it was definitaly to lean to run. This would have been missed entirely had the plan not been to take the carb apart to begin with. I now have the machine back and it runs like the day I brought it home. At least for now anyway. Again I appreciate all the information I recieved from you all.
ultangler
Nov 30, 2024 01:35 AM
Pehter
Oct 3, 2024 11:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
2many2ride
Sep 27, 2015 04:35 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
